Home » Audio » Source » Cleaning old records
Cleaning old records [message #82492] Mon, 25 April 2016 09:37 Go to next message
minora is currently offline  minora
My dad still has several old records lying around. He often decides against cleaning them out of fear that he will break the records. Eventually he only wipes it with tissues or dry cloth. I've heard that using detergent to clean them is not a good idea. Is it okay to only use water?
Re: Cleaning old records [message #82501 is a reply to message #82492] Mon, 25 April 2016 18:22 Go to previous messageGo to next message
Hi, you should look at the forum on vinylengine.com for info on this. There are lots of ways to clean LPs. Some quite simple like using non-concentrated Dawn dish soap and water. It gets more complicated from there. I personally use an ultra sonic bath type cleaner (with a water, wetting agent, drops of Dawn and some isopropol alcohol. This is followed by a distilled water rinse and a vacuum dryer. It will take a really grimy LP and make it quite nice in a matter of minutes. A popular LP cleaner is "SpinClean" Google it. For about $75 you get all you need to do about 100-150 LPs. Refills are cheap as well. It works pretty well.
Re: Cleaning old records [message #82536 is a reply to message #82501] Fri, 29 April 2016 09:18 Go to previous messageGo to next message
gofar99 wrote on Tue, 26 April 2016 07:22
Hi, thanks for the information. I'll look around for more info. I see some methods are more complicated than others. Is it related to the age of the records or how 'dirty' it looks?
Re: Cleaning old records [message #82540 is a reply to message #82536] Fri, 29 April 2016 15:29 Go to previous messageGo to next message
Hi, Yes there are many methods and some are rather complicated. For one batch of sticky LPs I first used Simple Green on them followed by my normal ultra sonic process. They had some gunk on them that was resistant to pretty much everything. The good news is that except for the labels LPs are pretty much immune to most cleaning processes. Do not use solvents on them though as some will dislove the vinyl.
How much effort to use...it depends on the individual LPs. If it looks clean then just some minimal procedures are in order. Something like a "Spin Clean" ought to be fine. Really cruddy ones...as much as you can do. The key is when you play the LP. If it plays well and you don't get a build of gunk on the stylus then it probably is fine. Just use a LP dust brush on it before playing. BTW, it is important to keep the stylus clean as well. I use VP Dust Buster. It is a small container of what looks like a gel. It works great. I trust it with my $1000+ Dynavector Ruby Karat cartridge so you can be pretty sure it is OK. It runs about $20 and does not ever need replaing.
Re: Cleaning old records [message #82681 is a reply to message #82492] Tue, 24 May 2016 09:42 Go to previous messageGo to next message
Finn is currently offline  Finn
Great information. I have a few records left and I'm deathly afraid to clean them because I don't want them to get ruined since they are so old. I'm going to look into getting a "SpinClean" and try it out.
Re: Cleaning old records [message #82691 is a reply to message #82492] Tue, 24 May 2016 12:24 Go to previous messageGo to next message
They say old is gold and I can imagine how angry your father would be if he found some of these records faulty.
I was once cautioned against using just water as a cleaning medium and thanks to the internet, I discovered the ultra sonic bath type cleaner. I have never been disappointed.
Re: Cleaning old records [message #82933 is a reply to message #82492] Sun, 26 June 2016 19:00 Go to previous messageGo to next message
Nouri is currently offline  Nouri
I never thought of using Simple Green. That's pretty crafty. Didn't there used to be a brush you could put on the stylus to clean a record after each use?
Re: Cleaning old records [message #82953 is a reply to message #82933] Tue, 28 June 2016 20:34 Go to previous message
Hi The brush was a clever idea at the time when turntables tracked at 3-6 grams. With most now in the 1-2 gram range and added mass to the tone arm is almost never desired the brushes have died off. You can still obtain a "Dustbuster" though. It is an external brush on its own arm that you set on the record so it will clean the record before that part gets to the stylus. When set up properly they track the record and also perform an anti static function. I have tried them and really find them unsatisfactory. A good microfiber cleaner brush used before you put the needle on the LP works as well and is not so finicky to set up and use.
Previous Topic: Replacing a CD lens
Next Topic: Cables with custom length
Current Time: Mon Nov 09 04:50:40 CST 2026
