Home » Audio » Thermionic Emissions » Feedback
Re: Feedback [message #8233 is a reply to message #8231] Wed, 09 June 2004 19:45 Go to previous messageGo to next message
SET lover is currently offline  SET lover
I think we're in agreement but I'd still have to say that SET is my personal preference.
Re: Feedback [message #8234 is a reply to message #8230] Wed, 09 June 2004 19:51 Go to previous messageGo to next message
As Wayne said, with SET amps you have a single driver and with PP amps you have a "push" side and a "pull" side. That means there can (and must) be some differences in the two sides and you also have the complexity of phase splitting. The input signal must be reversed to send to the "pull" side to make it opposite to the "push". A SET amp is more pure.
Re: Feedback [message #8235 is a reply to message #8232] Wed, 09 June 2004 22:38 Go to previous messageGo to next message
So if I understand correctly we are back to square one with SET's where the output impedance of the amp is subject to wildly fluctuating load impedances that are frequency derived and reflected back to the plate of the triode tube?
SET output impedance [message #8236 is a reply to message #8235] Thu, 10 June 2004 01:17 Go to previous messageGo to next message
They are sensitive to load impedance, that is true. The parallel feed configuration seems a little less so, perhaps since the transformer is resonated with the parafeed cap down low. Then again, I suppose a big output transformer can be used on a standard configuration to drop output impedance and make the system less sensitive. There have been some pretty substantive discussions about output transformers on this very subject. I guess that's probably the most important thing, maybe even more so than the output tube.
Re: And an even more indepth article [message #8263 is a reply to message #8222] Tue, 15 June 2004 13:30 Go to previous messageGo to next message
YEah you may be right! About the clippping i mean.
The ASUSA is doing really great. I put in an old RCA 12ax7, and a pair of new tesla el84s. After about 20 hours, it rocks. In my opinion it sounds better than the zen by a tad. Better soundstage and imaging. The zen sounds kind of like there is a film on the music.. i suspect becuase the asusa is tweaked wuth high quality coupling caps and a solen cap in the power supply, while the zen is stock (solen coupling caps which are not too bad thuogh).
I really like the asusa amp!
The one good thing... i no longer think the zen amp is the best amp!
MAde me break that slavish mindset!
-akhilesh
I like SETs too [message #8264 is a reply to message #8231] Tue, 15 June 2004 13:34 Go to previous messageGo to next message
With push pull, the amp sounds better than a SET.
With SET, the music sounds better than with a push-pull.
Go figure.
-akhilesh
Re: I like SETs too [message #8266 is a reply to message #8264] Tue, 15 June 2004 21:38 Go to previous message
Previous Topic: Ламповый Завод "Светлана"
Next Topic: Ultralinear
Current Time: Thu Nov 26 11:07:56 CST 2026
