Home » Sponsored » Pi Speakers » 3 Pi build in Italy...
3 Pi build in Italy... [message #81992] Wed, 10 February 2016 07:53 Go to next message
porfido1974 is currently offline  porfido1974
Hi,
First of all, sorry for my bad english...
I opened this thread to tell a REALLY BIG "thank you very much!!!" to Wayne!
These are the second couple of Pi Speakers I built and I couldn't be more satisfied and happy about them!
Of course my skills are far from good and the result is also...
I used 1" mdf for front and rear and added a brace...
index.php?t=getfile&id=1866&private=0
Painted the inside with many coats of waterproofing compound...
index.php?t=getfile&id=1867&private=0
Built separate filters...
index.php?t=getfile&id=1868&private=0
index.php?t=getfile&id=1869&private=0
index.php?t=getfile&id=1872&private=0
Made the horn recesses following this very good tutorial:
http://www.exquisiteaudio.com/baffle.html
index.php?t=getfile&id=1870&private=0
index.php?t=getfile&id=1871&private=0
Iron washers and putty for attaching the grills by magnets...
index.php?t=getfile&id=1874&private=0
index.php?t=getfile&id=1875&private=0
Reflex ducts made by some mdf rings glued together...
index.php?t=getfile&id=1873&private=0
Primer...
index.php?t=getfile&id=1876&private=0
Varnex paint by roller...
index.php?t=getfile&id=1877&private=0
Rubber feet...
index.php?t=getfile&id=1878&private=0
Drivers mounted...
index.php?t=getfile&id=1879&private=0
Grills attached...
index.php?t=getfile&id=1880&private=0
Ok and "How do they sound?"...
So good I keep smiling and smiling listening to them... Very Happy
THANK YOU VERY MUCH AGAIN, WAYNE!!!!
  • Attachment: img_2810.jpg
    (Size: 207.65KB, Downloaded 2543 times)
  • Attachment: img_2813.jpg
    (Size: 205.59KB, Downloaded 2425 times)
  • Attachment: img_2814.jpg
    (Size: 115.58KB, Downloaded 2437 times)
  • Attachment: img_2815.jpg
    (Size: 100.40KB, Downloaded 2472 times)
  • Attachment: img_2816.jpg
    (Size: 148.91KB, Downloaded 2492 times)
  • Attachment: img_2817.jpg
    (Size: 176.75KB, Downloaded 2476 times)
  • Attachment: img_2910.jpg
    (Size: 187.25KB, Downloaded 2391 times)
  • Attachment: img_2911.jpg
    (Size: 87.70KB, Downloaded 2447 times)
  • Attachment: img_4010.jpg
    (Size: 91.85KB, Downloaded 2391 times)
  • Attachment: img_4110.jpg
    (Size: 197.13KB, Downloaded 2433 times)
  • Attachment: img_4111.jpg
    (Size: 147.22KB, Downloaded 2371 times)
  • Attachment: img_4113.jpg
    (Size: 185.30KB, Downloaded 2462 times)
  • Attachment: img_4116.jpg
    (Size: 183.30KB, Downloaded 2466 times)
  • Attachment: img_4211.jpg
    (Size: 143.13KB, Downloaded 2461 times)
  • Attachment: img_4212.jpg
    (Size: 175.69KB, Downloaded 2485 times)
Re: 3 Pi build in Italy... [message #81995 is a reply to message #81992] Wed, 10 February 2016 08:35 Go to previous messageGo to next message
Lookin' good!
Re: 3 Pi build in Italy... [message #82014 is a reply to message #81992] Fri, 12 February 2016 09:27 Go to previous message
porfido1974 wrote on Wed, 10 February 2016 05:53
Thanks for that link. I was going to surface mount my horns/woofer, but with this info I think I can now recess them.
Previous Topic: 4pi speaker plans
Next Topic: Pi Stage 4 upgrade to JBL 2226
Current Time: Fri Nov 13 05:13:37 CST 2026
