Home » Sponsored » Pi Speakers » 7Pi plans
7Pi plans [message #81610] Wed, 07 October 2015 09:39 Go to next message
BruceK is currently offline  BruceK
Hello,
Could you please send me the 7Pi plans.
Thanks Razz
Re: 7Pi plans [message #81611 is a reply to message #81610] Wed, 07 October 2015 15:45 Go to previous messageGo to next message
You've got mail!
Re: 7Pi plans [message #81735 is a reply to message #81610] Mon, 14 December 2015 11:24 Go to previous messageGo to next message
lenok30.87 is currently offline  lenok30.87
Can you send me plans?
I want build universal speakers for modern music (trance) and for jazz maybe you can describe in a few words differences between 4pi and 7pi. I mean to compare 4pi and 7pi in different styles of music.
Thank you, very much!
Re: 7Pi plans [message #81736 is a reply to message #81735] Mon, 14 December 2015 16:12 Go to previous messageGo to next message
The tonal balance is the same, but constant directivity cornerhorns have an advantage in that they do not suffer coloration from early reflections like all other forms of speakers do. They are acoustically close enough to nearest boundaries to act as though they were baffled by the boundaries. They make the wall behind and beside the speaker become a launch point, like a ground plane. So if you have a room with the right corners to support constant directivity cornerhorns, use them. If not, DI-matched mains with flanking subs are the next best thing.
See these links for more information:
Re: 7Pi plans [message #81742 is a reply to message #81610] Thu, 17 December 2015 13:50 Go to previous messageGo to next message
antonio7319 is currently offline  antonio7319
Hello,
Thanks
Re: 7Pi plans [message #81754 is a reply to message #81742] Fri, 18 December 2015 08:52 Go to previous messageGo to next message
You've got mail!
Re: 7Pi plans [message #81758 is a reply to message #81610] Fri, 18 December 2015 11:42 Go to previous messageGo to next message
ciao
ho un woofer eminence kappa 15a american standard
può andare bene al posto del eminence omega 15
bay
scusate per l'inglese
Hello
I woofer eminence kappa 15a american standard
can fit in place of eminence omega 15
bay
sorry for English
Re: 7Pi plans [message #81764 is a reply to message #81758] Fri, 18 December 2015 15:33 Go to previous messageGo to next message
In the seven π speaker, you can substitute that woofer but in the four π speaker, you can't.
Re: 7Pi plans [message #81765 is a reply to message #81610] Fri, 18 December 2015 15:51 Go to previous messageGo to next message
ok allora e possilbile la sostituzione nel 7
ok then and possible replacement in 7
Re: 7Pi plans [message #82231 is a reply to message #81610] Thu, 17 March 2016 04:35 Go to previous messageGo to previous message
wagner71 is currently offline  wagner71
My listening room is very small, only 7 feet 10" wide, and 14 feet long. Could 7pi speakers still be ok in this room? What is minimum recommended listening distance for 7 pi speakers?
If you think they might work, could you send me the plans?
Previous Topic: 1Pi Plan and Crossover
Next Topic: 2pi Tower Plans
Current Time: Sun Nov 22 18:23:03 CST 2026
