Home » Audio » Speaker » Mono "flanking sub"
Re: Mono "flanking sub" [message #81689 is a reply to message #81688] Fri, 27 November 2015 16:23 Go to previous messageGo to previous message
The signal type you use to measure in-room bass isn't too critical, as long as you use a method that doesn't gate out reflections. We're looking at the sound field, not trying to isolate the direct sound as a pseudo-anechoic measurement would. So white or pink noise are fine, as as are sweeps. Noise is broadband, while swept-sines are monotonic, but either signal type is fine provided we excite and sample over a long enough period of time to include the reflections from the room.
If we were measuring speakers, I'd suggest the exact opposite. I would want a reflection-free measurement. That's because I would want to know what the speaker does without influence from the environment it is used in. But in this case, we are measuring the speaker and room as a system, and we're looking at the behavior in the modal region. So we really need to see the room reflections and how they affect the sound field.
Previous Topic: One Speaker Wi-Fi
Next Topic: Class d for flanking subs
Current Time: Fri Nov 06 23:08:50 CST 2026
