Home » Sponsored » Pi Speakers » Implementation
Implementation [message #81608] Mon, 05 October 2015 02:35 Go to next message
audiophile.1963 is currently offline  audiophile.1963
I own this set of speakers: JBL 2225h, 2105h and JBL JBL 2403h. My idea is to build a compact reflex speaker and would like to load with an horn the JBL 2105h. In the project Seven PI mid Horn are used a JBL 2012 or a Delta 10, speakers 10" while my JBL 2105 is a 5" and must be cut higher. What horn I have to build? Surely throat and mouth will be lower than the ones of the Seven PI mid Horn. I want to use these speakers unused for some time. In addition what cuts of crossover do you recommend? Anyone can help me?
Thank you for all
Giuseppe
Re: Implementation [message #81609 is a reply to message #81608] Tue, 06 October 2015 17:57 Go to previous message
That sounds like an excellent project. I absolutely loved those 2105 midranges - I used them for some time. But they are not suitable for the midhorn I use with 10" drivers.
Previous Topic: 4 Pi Build Progress
Next Topic: 4pi LCR new Project
Current Time: Thu Nov 05 08:04:21 CST 2026
