Home » Audio » Speaker » Johnny5's four Pi build
Re: Johnny5's four Pi build [message #81441 is a reply to message #81440] Wed, 08 July 2015 08:47 Go to previous messageGo to previous message
If you have two good corners, I'd suggest building constant directivity cornerhorns to take advantage of them. They are designed for that placement, and maintain acoustic proximity to the boundaries appropriate for the wavelengths involved. The bass bin and mid horn both work to achieve this goal.
Otherwise, use flanking subs to mitigate the anomalies that invariably arise from placement near boundaries. That's the next best thing, because you cannot get any other kind of speaker acoustically close to the boundaries, and most times, you can't get them far enough away either. So the use of DI-matched waveguide mains with flanking subs are the best option.
Previous Topic: Digging out the old (?) ART array - some questions
Next Topic: Flanking subs
Current Time: Mon Nov 09 21:32:34 CST 2026
