Barzilay 4pi [message #81305] |
Sat, 09 May 2015 17:21 |
Jeff V.
Messages: 11 Registered: April 2015
Chancellor |
Thought I would share my 4pi build. Although I am using the 4pi crossover & recommended drivers I am using some vintage Barzilay cabinets. Stuffed the cabinets come in at 4 cubic feet.
I started by cutting the baffle which is 3/4" mdf.
You may notice a frame around the baffle. This was needed to install speaker cloth.
Making a stereo pair I chose to build them mirrored.
I tried to keep my build as close as possible to to Wayne's 4pi. The bracing and port placement are based on the 4pi instructions.
I still need to do some cabinet sealing and add some insulation. Also need to properly mount the crossover & do some wire management.
Even though they are not finished I have them set up, playing music. Sound great! If they improve once finished all the better!
Re: Barzilay 4pi [message #81439 is a reply to message #81438] |
Tue, 07 July 2015 10:42 |
Messages: 18761 Registered: January 2001
Sorry, I missed this earlier. The question was asked whether tuning at 38Hz should be modified and increased to 40Hz.
I designed the system for 38Hz tuning. But really, the difference in response that results from a Helmholtz frequency of 40Hz is so slight, it almost is undetectable. Just a smidge in the response below 100Hz. I'd consider the "difference" to be so small as to be overshadowed by tolerance, driver operating parameter shifts, etc. So don't worry about increasing the Helmholtz frequency a couple Hertz. It won't do anything.
What I am always concerned about are response anomalies caused by intermal standing waves. That's what I'd watch for, and why I would want measurements. These would likely be above 100Hz, in the 100Hz to 300Hz region. I'd look for blips and ripples in response. They can usually be mitigated by port and/or midwoofer driver placement, and by proper placement of damping material.
I already know how the standard four π loudspeaker cabinet acts. It's behavior is well-known. But we cannot really know how this modified Barzilay cabinet acts without measurements.
So if you have the time and inclination, get some measurement software, take the cabinets outside and measure one of them. Lie it on its back, facing upwards and hang the microphone above it. Put it in a pit or create a baffle extension, something that extends the face of the speaker out a long way to prevent a delayed reflection off the ground under the speaker. Watch for ripple in the 100-300Hz region.
