Home » Sponsored » Pi Speakers » 7PI questions
Re: 7PI questions [message #81162 is a reply to message #81145] Fri, 20 February 2015 06:24 Go to previous message
Hey Ben, welcome.
As you peruse, you'll see Wayne has amassed a serious amount of info and then a couple of years back arranged it into the FAQs. (Whew!)
It's a lot to go through so bouncing back and forth with specific questions is a great approach.
I'm gonna go out and say it:
Wayne's 7 Pi speaker is the best corner speaker out there!
Tried and true, professionally documented/measured, precise plans, etc ... oh, and free, robust, life-time support as you are experiencing!
OK, the big '?'
Corner speakers need corners. Tell us about your room.
The 7 Pi works best on the short wall, crossing in front of the listener with ~5ft of uninterrupted wall on both sides of the speaker. (Ideal)
Wayne [finalllllllllllllllly, Wink ] has the flat-pack midhorn kits back in stock so if you're not up-to-snuff with wood working (like me) you can easily get goin'
Speaking of get goin', the 7 Pi also has many entry points!
inexpensive: PSD2002/alpha or delta10 and your own bassbin
to
Full-on best drivers, xover components, cabinets.
Cheers,
Jeff
Previous Topic: request crossover + plans four pi 2226
Next Topic: Request for Plans for 4pi Speakers and crossovers
Current Time: Sun Oct 18 14:29:57 CDT 2026
