Home » Sponsored » Pi Speakers » One more Four Pi crossover question
One more Four Pi crossover question [message #81021] Sat, 17 January 2015 16:50 Go to next message
timhowell01 is currently offline  timhowell01
Hopefully this is my last question about assembling the Four Pi crossover. I seem to be unable to solder the leads from the 100W 8 ohm dummy load resistor to the other components. I'm using a new soldering tip that is working fine for other components, on a 40 W soldering iron. 60/40 rosin core solder. Any ideas?
Re: One more Four Pi crossover question [message #81022 is a reply to message #81021] Mon, 19 January 2015 22:35 Go to previous messageGo to next message
The lugs may be coated with shallac or something similar. You might want to cut the lugs and solder directly to the wire.
We insert the wire into 0.205" lugs which connect to the circuit board. So we don't use the screw-mount lugs. I think those screw-mount lugs are coated, and depend on the fasterner to bite through the coating to ensure electrical connection.
Re: One more Four Pi crossover question [message #81024 is a reply to message #81022] Wed, 21 January 2015 23:00 Go to previous message
Cutting them off and soldering directly took care of it.
--TWH
Previous Topic: Rs in Four Pi Crossover
Next Topic: Speaker placement and wavefront launch, revisited
Current Time: Tue Oct 20 12:35:49 CDT 2026
