Home » Sponsored » Pi Speakers » Four Pi Crossover Assembly
Four Pi Crossover Assembly [message #80974] Sun, 04 January 2015 14:43 Go to next message
timhowell01 is currently offline  timhowell01
I'm just starting a Four Pi build. Is there any reason not to just assemble the crossover components on a piece of cardboard or a thin piece of wood instead of using the PCB? I've done this once before with a simpler crossover, but not sure if the number of components in the Four Pi crossover might make it a little tricky.
Thanks,
--TWH
Re: Four Pi Crossover Assembly [message #81003 is a reply to message #80974] Thu, 08 January 2015 15:27 Go to previous message
Sure, you can do that. Many people have. I think using the PCB is easier and more attractive, but there is nothing wrong with using a breadboard or any other form of point-to-point assembly. Just be sure all coils are arranged to reduce coupling and minimize mutual inductance.
Previous Topic: 4 pi plan request
Next Topic: delivery and dispatch
Current Time: Tue Oct 20 12:34:16 CDT 2026
