Home » Sponsored » Pi Speakers » Subs to pair with 2 Pi or 4 Pi
Subs to pair with 2 Pi or 4 Pi [message #80932] Fri, 12 December 2014 23:24 Go to next message
timhowell01 is currently offline  timhowell01
I built a pair of 2 Pis earlier this year, and am getting ready to start a 4 Pi build. I think I am also going to build a sub or two to go with my speakers. I know about the 3 Pi sub, but am also considering the Anarchy Tapped Horn. What should I be looking for in a sub to pair with these speakers?
Thanks in advance,
--TWH
Re: Subs to pair with 2 Pi or 4 Pi [message #80933 is a reply to message #80932] Sat, 13 December 2014 08:01 Go to previous messageGo to next message
Flanking subs need to be capable of smooth output up into the lower midrange. It's just as important that they be they be faithful at medium-range frequencies as low. So they're called to take on more than just subwoofer duty. As for traditional subs or distributed multisubs - as long as crossover is kept below ~80Hz or so - then all you need is good clean bass.
Re: Subs to pair with 2 Pi or 4 Pi [message #80952 is a reply to message #80933] Tue, 23 December 2014 16:40 Go to previous messageGo to next message
Hi Wayne what range would you consider flanking subs to extend into medium range to be? 150hz?
Re: Subs to pair with 2 Pi or 4 Pi [message #80954 is a reply to message #80952] Wed, 24 December 2014 09:57 Go to previous messageGo to next message
Well, yes, they need to be clean at 150Hz, but to me that means I would really like to see them be smooth up to 300Hz so a shallow rolloff slope can be used. The key is blending, so we don't want an abrupt rolloff.
Re: Subs to pair with 2 Pi or 4 Pi [message #80955 is a reply to message #80954] Wed, 24 December 2014 13:52 Go to previous messageGo to next message
I have much work to do.......
What subwoofers can play that high? Open baffle?? Bandpass?
Re: Subs to pair with 2 Pi or 4 Pi [message #80956 is a reply to message #80955] Wed, 24 December 2014 18:05 Go to previous message
Direct radiating woofers usually work best for flanking subs. But some front-loaded basshorns can work well too.
Previous Topic: Pi = ahhhhhh
Next Topic: 4 pi plan request
Current Time: Tue Oct 20 12:34:49 CDT 2026
