Home » Sponsored » Pi Speakers » Two PI: A Little Bright OR Light in the Bass?
Re: Two PI: A Little Bright OR Light in the Bass? [message #80913 is a reply to message #76092] Tue, 09 December 2014 12:11 Go to previous messageGo to previous message
themilford is currently offline  themilford
Ok, making my next pair for a friend.
I'm using 3/4" Finland Birch this time so I'm slightly increasing the size accordingly. will be locating the port on the front this time as well...
One question, I don't have tube stock for the port so figured I can sandwich a 2.25" square of stock to the front baffle making up the 1.875" length of the port and drill a 2" hole through that. This should add some mass and bracing to the front. But I notice that the plans call for the port I.D. to be 1.91" and my bit is exactly 2". how would I adjust the length of the port to make up for this?
Also, is it ok to center the port on the bottom?
And finally, has anybody put in the time to measure out a slightly smaller TwoPi Tower? I would love to simply double the volume of the regular TwoPi but I don't have the software or knowledge to work this out. Having a TwoPi with a tad more bass that that doesn't need a stand but isn't as huge as the TwoPi Tower would be fantastic for me and my WAF.
Cheers,
DJ
Previous Topic: Older ThreePi kit
Next Topic: 2227h vs 2226h for 4pi
Current Time: Tue Oct 20 04:30:58 CDT 2026
