Home » Sponsored » Pi Speakers » Will 7Pi work in my room?
Re: Will 7Pi work in my room? [message #80834 is a reply to message #80793] Sat, 15 November 2014 03:50 Go to previous messageGo to previous message
despearce is currently offline  despearce
Well finally finshed reading and researching, plus spoke to a gent in the uk who has used 7pi for the past 6 years. We have heavy curtains from floor to ceiling covering the window, they start 50" from the corner, will this help balance the soundstage?
A last few questions to ask:
Will the room being on the first floor be a problem, it is carpeted but is pine floorboards on joists?
Woud the 6pi be a better bet or is the 7pi better integrated and better sounding in the lower frequencies. Looking on here it seems as if the 6 goes lower and sounds identical over 100hz?
Finally assuming the floor will not cause major problems could you send me the 6pi plans please or the 7pi if they will cause less room issues. I want these to be a long term part of my system so have decided to spend what it takes to achieve the sound I'm after.
Previous Topic: What to use to power/EQ a 4.2 theater?
Next Topic: Guidance when looking for used 2226Hs?
Current Time: Fri Nov 06 11:58:28 CST 2026
