Re: 7Pi Build 2014 [message #80478 is a reply to message #80113] Sun, 14 September 2014 11:15 Go to previous messageGo to previous message
First thing, it seems that 2226h are wired "black to + forces positive displacement". Good to know.
I will fix that in the XO box as well as the other suggestions.
The resistor came off by itself inside the XO box. It's a mystery because nothing could have knocked it off.
How much clearance is optimal between the mid cone and the panel it's mounted to?
Mid horn bracing is not an issue.. The back panel seal is not perfect now but I will fix that once I determine the proper clearance for the mid driver.
Next Topic: Best Amps for 3Pi
Current Time: Tue Oct 20 19:12:12 CDT 2026
