Home » Audio » Home Theater » Looking for an HDTV antenna
Looking for an HDTV antenna [message #80199] Tue, 15 July 2014 21:06 Go to next message
Round2 is currently offline  Round2
I have a small HDTV in the kitchen and want to put an antenna on it to see if I can pick up local stations. We don't have cable or satellite hooked up to it. Anyone know a good antenna that would work?
Re: Looking for an HDTV antenna [message #80203 is a reply to message #80199] Wed, 16 July 2014 10:50 Go to previous messageGo to next message
I've had good luck with amplified antennas. The ones that look like a plate aren't unattractive either.
Re: Looking for an HDTV antenna [message #80349 is a reply to message #80199] Sun, 31 August 2014 07:40 Go to previous message
We have a couple digital antennas. If you are concerned about aesthetics, get the one that looks like a flat square and attaches to a window. It seems to work as well as the more traditional-looking antenna.
Previous Topic: Which is the better streaming device?
Next Topic: 4K ultra HD televisions
Current Time: Fri Oct 30 18:39:23 CDT 2026
