Home » Sponsored » Pi Speakers » How to improve?
How to improve? [message #79502] Wed, 19 February 2014 14:16 Go to previous message
jgoodd8050 is currently offline  jgoodd8050
I'd like to get some input on how to improve bass response for this room. Left and right speakers are 7pi's that I enjoy very much. Adding subs is an obvious next step. The front wall is perfect for an IB sub system if the location proves good. I should probably build a small sealed sub to test... The back hall might be good for small sealed or ported.
Room dimensions are 7H x 11W x 17L.
I have "supper chunk" style absorption above the 7pi's.
Sound pannels are 2" thick, mounted on the wall.
The frequency response graph has no smoothing.
Measurements were taken from the listening position.
I run 60% music and 40% movies.
Objectives:
Smoother responce under 200hz.
Extension flat to 10-15hz at 110db.
Questons:
How would the multi-sub approach work with the 7pi's?
Do I need to be concerned about phase issues between the 7pi's subs on the front wall?
How high should I cross over the subs? (might effect driver choice)
What am I missing?
Thank in advance for the help!
Jeremy
index.php?t=getfile&id=1426&private=0
index.php?t=getfile&id=1427&private=0
  • Attachment: test.jpg
    (Size: 64.87KB, Downloaded 3795 times)
  • Attachment: HT Room.jpg
    (Size: 194.64KB, Downloaded 3910 times)
Previous Topic: Restoring a 1951 Philco 5W mono console... Thinking a 7 Pi! (Have a few questions)
Next Topic: Hi and a Few Questions
Current Time: Fri Nov 27 05:53:07 CST 2026
