Home » Audio » Room Acoustics » More Isn't Necessarily Better?
More Isn't Necessarily Better? [message #76306] Mon, 15 April 2013 17:55 Go to next message
iLoveiPod is currently offline  iLoveiPod
I was reading an article about speakers earlier today, and part of the article said that it is a "common misconception" that adding more speakers to a room will improve that room's acoustics. Thoughts?
Re: More Isn't Necessarily Better? [message #76308 is a reply to message #76306] Mon, 15 April 2013 18:47 Go to previous messageGo to next message
It depends on their directivities and where you put them. Certainly arbitrary placement is a problem.
Re: More Isn't Necessarily Better? [message #76509 is a reply to message #76306] Fri, 26 April 2013 11:11 Go to previous messageGo to next message
Chicken is currently offline  Chicken
I agree with Wayne. It's much more complicated than throwing more speakers at the problem. I also think that certain rooms are so bad that there is a limit to what even careful sound design can do, but they are likely few and far between.
Re: More Isn't Necessarily Better? [message #77293 is a reply to message #76306] Fri, 26 July 2013 07:01 Go to previous messageGo to next message
If it were as easy as just throwing a few more speakers in a room, there wouldn't be a need for sound designers. Placement and directionality matter.
Re: More Isn't Necessarily Better? [message #77540 is a reply to message #76306] Tue, 20 August 2013 17:18 Go to previous messageGo to next message
Azuri is currently offline  Azuri
More sound doesn't necessarily mean better sound in my opinion. It could actually make matters worse if you have a small room with a bad design that causes bad acoustics.
Re: More Isn't Necessarily Better? [message #79464 is a reply to message #76306] Sat, 15 February 2014 21:45 Go to previous messageGo to next message
Headphones is currently offline  Headphones
I think it depends on the overall quality and sound of the speakers. Quality over quantity. Having a lot of low-quality speakers isn't going to do much for you.
Re: More Isn't Necessarily Better? [message #80102 is a reply to message #79464] Tue, 17 June 2014 20:01 Go to previous messageGo to next message
Maille is currently offline  Maille
You're right about quality versus quantity. A good set of speakers that create great sound versus a bunch of cheap speakers where there is no care in the construction is a no-brainer.
Re: More Isn't Necessarily Better? [message #80345 is a reply to message #76306] Sat, 30 August 2014 15:14 Go to previous message
I can see how people come to that erroneous conclusion. If you can't hear something well, adding more speakers seems logical, but it ignores the possibility of other acoustical issues, like waveform interference.
Previous Topic: Sound dampening a room
Next Topic: Music in the waiting room of our office
Current Time: Fri Nov 13 06:26:46 CST 2026
