Home » Audio » Silicon Valley » Reference Line 2000 vs. 3000 Passive Preamp?
Reference Line 2000 vs. 3000 Passive Preamp? [message #7921] Sat, 07 October 2006 09:37 Go to next message
Vinylly is currently offline  Vinylly
I presently own a Reference Line 2000 passive preamp, however I found a Reference Line 3000 at a local shop. Other then the 3000 having a fancier front plate then the 2000, I'm wondering what the internal differences are. The heart and soul of a passive preamp is the attenuater, the 2000 has the british Penny/Giles and the wiring is solid silver 'Kimber' wire. Does anyone know what the attenuater of the 3000 is, or what the difference is between the two preamps that would make it a step up if I made a trade.
I dearly love my Reference Line passive preamp and the only time I would get rid of it would be for a step up.
Re: Reference Line 2000 vs. 3000 Passive Preamp? [message #7922 is a reply to message #7921] Sun, 08 October 2006 11:21 Go to previous messageGo to next message
Is the Reference Line 2000 that you have basically just a switch and attenuator? Seems to me that's perfect for some systems with plenty of drive and no need for an additional input gain stage.
Re: Reference Line 2000 and 2000 [message #7923 is a reply to message #7922] Mon, 09 October 2006 09:19 Go to previous messageGo to next message
Both are just switches with an attenuator. All solid silver wiring by Kimber. I us 18" of Kimber solid silver leads. They work wonderfully if you have a good robust tube amp., the very best with my old VTL Compact monoblock 100's with EL 34 tubes. (not so good on 'weany' amps.)
Re: Reference Line 2000 and 2000 [message #7924 is a reply to message #7923] Mon, 09 October 2006 13:58 Go to previous message
Very good. I agree with you, that approach seems to work well on tube amps. With sources that have enough drive, an extra gain stage isn't needed.
Previous Topic: Cambridge Audio
Next Topic: Color Me "Transparent"
Current Time: Fri Oct 23 06:54:55 CDT 2026
