Re: 3 PI build [message #79046 is a reply to message #78971] Thu, 23 January 2014 17:26 Go to previous messageGo to previous message
BFP is currently offline  BFP
Now it's time to build the box and brace it. I started by gluing the top and sides to the baffle then added the bottom. Clamps were left on for a few hours and the boxes left for 24hrs before being handled.
index.php?t=getfile&id=1384&private=0
index.php?t=getfile&id=1385&private=0
index.php?t=getfile&id=1386&private=0
Next up, bracing. I'm a fan of using a lot of bracing inside cabinets, especially large ones. I decided on 2 window braces, one below the horn and one between the port and the woofer. I also added a brace at the mid point of the woofer and stick braces on all the panels. Cutting or routing braces can be a lot of work. I cut this down by gang drilling the corners of the 4 window braces and cutting as much as possible on the mitre saw. I only had to do the short sides with the jig saw.
4 brace blanks stacked and clamped in place for drilling with a forstner bit.
index.php?t=getfile&id=1387&private=0
One of the braces being installed
index.php?t=getfile&id=1388&private=0
  • Attachment: DSCF9576.jpg
    (Size: 190.79KB, Downloaded 8833 times)
  • Attachment: DSCF9577.jpg
    (Size: 185.40KB, Downloaded 8913 times)
  • Attachment: DSCF9575.jpg
    (Size: 170.25KB, Downloaded 8860 times)
  • Attachment: DSCF9580.jpg
    (Size: 191.69KB, Downloaded 8885 times)
  • Attachment: DSCF9592.jpg
    (Size: 160.88KB, Downloaded 8823 times)
Next Topic: Happy Pi Day
Current Time: Sun Nov 08 17:49:24 CST 2026
