Home » Audio » Silicon Valley » memory presets won't hold frequency
Re: memory presets won't hold frequency [message #7889 is a reply to message #7888] Mon, 24 April 2006 18:59 Go to previous messageGo to previous message
If there is a large capacitor or battery connected to a pin on the tuner integrated circuit, that's what you'll want to replace. It may be placed after a diode in the line so that the cap or battery supplies power only to the preset memory when power is off. That's how you can probably identify it. Then again, it may be internal to the chip, and if that's the case, you'll have to replace the chip to fix the problem.
Previous Topic: The JVC RX DP 9 ... A Nice Receiver .
Next Topic: NAD amps.
Current Time: Tue Sep 15 10:16:19 CDT 2026
