Home » Sponsored » OddWatt Audio » KT120 Class A Push-Pull U/L Mono-Blocks
Re: KT120 Class A Push-Pull U/L Mono-Blocks [message #78871 is a reply to message #78836] Fri, 03 January 2014 23:00 Go to previous messageGo to previous message
Hi, Go to the diyaudioprojects.com forum on tubes. There are numerous comments. Also on Oddwatt amps in the same section. As for difficulty they are rather easy to build and trouble free. The KT120 mono blocks weigh about 30 pounds each when you use the recommended transformers. Since the amps were designed aroung those particular transformers the use of others may (or may not) compromise various aspects of the performance and stability.
Previous Topic: Thing To Come
Next Topic: LSAF
Current Time: Sun Oct 25 09:24:55 CDT 2026
