Home » Sponsored » Pi Speakers » Corners and frequencies
Re: Corners and frequencies [message #78649 is a reply to message #78648] Fri, 13 December 2013 14:23 Go to previous messageGo to previous message
Pretty much what I had expected, but I was curious about the degree to which a corner could widen the directivity of a midwoofer (facing outwards) when the frequency rises to that range where it starts to narrow in a (non-horn) enclosure out in the room. My use of the 2Pi example was more to pose the question than an expectation that it might sort-of work.
A second relevant issue is that I would think you would want to have the mid and high range sound coming out of the corner at mid-screen height. If you were to raise the entire 6Pi or 7Pi unit several feet, you would change the 3-surface corner loading of the low frequencies. Would it make sense to build two low-frequency boxes for each corner with one on the floor, driver in the low position, and the other in normal configuration elevated so the midhorn is at, say 60-70 inches?
Thanks,
Skip
Previous Topic: 1 Pi and 2 Pi Plans
Next Topic: Speaker locations
Current Time: Wed Nov 04 15:18:57 CST 2026
