Home » Audio » Source » need help with replacement receiver (modern sound?)
need help with replacement receiver [message #78334] Sun, 10 November 2013 13:32 Go to next message
oldschool is currently offline  oldschool
Please either give me suggestions or refer me to a source for information.
I am trying to replace my 1969 Heathkit stereo receiver. I have found few stereo receivers at reasonable prices. I was going to purchase a Onkyo TX-8050 which has a phono input. I will be using a Technics SL-BD22 turntable. Will this work? I have read some reviews that indicate that I will need a preamp for some turntables. Any guidance or help will be gratefully received.
Thank you
Re: need help with replacement receiver [message #78336 is a reply to message #78334] Sun, 10 November 2013 17:06 Go to previous message
Hi, The specs show that it is equipped for MM phono input. SO unless you have what is known as a low output moving coil cartridge you will be fine. If you let us know what the cartridge is we can verify that it is OK.
Previous Topic: DAT to CD
Next Topic: Reel to Reel Tape Recorders
Current Time: Mon Nov 09 07:27:52 CST 2026
