Home » Audio » Craftsmen » DIY Diffuser
Re: DIY Diffuser [message #78312 is a reply to message #78308] Thu, 07 November 2013 21:06 Go to previous messageGo to previous message
Hi, I use only one at present but there are lots of wall hangings as well. I needed to tame the reflections off a fireplace and exterior wall that had a smooth finish. I made a frame or if you would rather call it a stand for a quilted pad designed for pro audio studios. You can order them from some companies that sell moving supplies. Very heavy weight and thick. It is fastened at the top with curtain rings. Works fine and was cheap. When my system was in another room I used foam blocks mounted on thin wood backing in several locations to reduce side reflections. The foam pieces came in laser toner boxes. The company I worked for then used lots of them. They are the kind that looks like a lot of fingers sticking up.
index.php?t=getfile&id=1337&private=0
Previous Topic: Laser Harp and Arduina
Next Topic: Affordable Parts Online
Current Time: Thu Nov 26 04:10:52 CST 2026
