Home » Sponsored » Pi Speakers » Need an easy to use designer better than WinISD
Need an easy to use designer better than WinISD [message #78280] Mon, 04 November 2013 09:47 Go to next message
Whenever I try to see what enclosure WinISD has for 2 woofers it yields a box twice as big as for 1 woofer.
How can there be so many speakers with 2 woofers, or more, MTMs come to mind, that are not side-by-side refrigerators?
Re: Need an easy to use designer better than WinISD [message #78282 is a reply to message #78280] Mon, 04 November 2013 10:22 Go to previous messageGo to next message
Maybe add the second woofer in its own separate box, as a helper woofer? It will be more flexible that way, and you can use that to your advantage.
Re: Need an easy to use designer better than WinISD [message #78304 is a reply to message #78280] Wed, 06 November 2013 22:48 Go to previous messageGo to next message
Iron-law, right? Small, loud, low--pick-two. Give-up effic or bass and you're home free. There's always EQ and active stuff. Besides, nothing says refrigerators are All bad (and you get 16Hz organ w/o needing no steenkeen subs).
index.php?t=getfile&id=1334&private=0
Re: Need an easy to use designer better than WinISD [message #78305 is a reply to message #78304] Thu, 07 November 2013 00:47 Go to previous message
Nice!
Previous Topic: Could this be Peace In Our Time?
Next Topic: pi4 / pi12
Current Time: Mon Nov 23 07:59:21 CST 2026
