Home » Audio » Silicon Valley » Curcuit breaker going off on Yamaha RX-385
Re: Curcuit breaker going off on Yamaha RX-385 [message #7826 is a reply to message #7825] Sun, 19 June 2005 13:34 Go to previous message
chris is currently offline  chris
Thanks very much for taking the time to think about my problem. Its very kind of you to have done so.I may not be in the position where this could happen again as i am expecting to pick up a used pair of Hales Concept III's which if i remembercorrectly are not bi-wireable.I will need to upgrade from the Yamaha receiver though as neat as that has been.I can finally put my KEF 690Q's in boxes back into the Van.I had them running off the high end posts as the AR9's tweeters do not work and that's where the loose wire developed.Thanks again.
Previous Topic: Help! - Converting Constant Voltage Amp!
Next Topic: Yet More on Sonic Impact
Current Time: Sun Nov 15 10:49:43 CST 2026
