Re: 4Pi with feet [message #78155 is a reply to message #78127] Mon, 21 October 2013 01:04 Go to previous messageGo to next message
Nice work your doing there.
Re: 4Pi with feet [message #78203 is a reply to message #78127] Sat, 26 October 2013 13:25 Go to previous messageGo to next message
Well, 98% done!!! Smile
The 2% that needs to be done involves: Fixing a dent I made when moving one of the speakers, just a little part of the top veneer. Then connecting everything, some screws, some insulating and done!!!
Tomorrow I'll post the finished work, I hope, I don't have much time...
Hope you like it. Smile
Lucas.
index.php?t=getfile&id=1307&private=0
index.php?t=getfile&id=1308&private=0
index.php?t=getfile&id=1309&private=0
index.php?t=getfile&id=1310&private=0
index.php?t=getfile&id=1311&private=0
index.php?t=getfile&id=1312&private=0
index.php?t=getfile&id=1313&private=0
index.php?t=getfile&id=1314&private=0
index.php?t=getfile&id=1315&private=0
index.php?t=getfile&id=1316&private=0
index.php?t=getfile&id=1317&private=0
index.php?t=getfile&id=1318&private=0
Re: 4Pi with feet [message #78204 is a reply to message #78203] Sat, 26 October 2013 17:30 Go to previous messageGo to next message
Lookin' good!
icon14.gif  Re: 4Pi with feet [message #78205 is a reply to message #78204] Sun, 27 October 2013 04:10 Go to previous messageGo to next message
Those look sweet, nice woodworking. Smile
What caps did you use?
Re: 4Pi with feet [message #78206 is a reply to message #78205] Sun, 27 October 2013 09:44 Go to previous messageGo to next message
Thanks Nick!
I named them The Quadrupeds, but my girlfriend says they look like a Minion (those little creatures from the movie Despicable Me) Smile
The caps are Dayton audio, The crossovers are standard from Wayne.
Yesterday I applied some modelling clay and tape, today if I find some time I'll apply the insulation, connect everything and test them.
Re: 4Pi with feet [message #78210 is a reply to message #78127] Mon, 28 October 2013 07:28 Go to previous messageGo to next message
What type of screw do you recomend?
I have black wood screws like this one, but I've just seen that some people sells this kind of screws, mostly for professional speakers, but I don't know if they are better or not.
The second one is quite more complex to install, and I dont really know where to buy them where I live...
Re: 4Pi with feet [message #78212 is a reply to message #78210] Mon, 28 October 2013 08:13 Go to previous messageGo to next message
I prefer T-Nuts, those shown in your second link.
Re: 4Pi with feet [message #78213 is a reply to message #78212] Mon, 28 October 2013 14:53 Go to previous messageGo to next message
I can buy here 1/4" t-nut, but no 10-32. Is t ok?
Re: 4Pi with feet [message #78214 is a reply to message #78213] Mon, 28 October 2013 18:30 Go to previous messageGo to next message
Thread pitch doesn't matter too much, as long as screw and nut match.
Re: 4Pi with feet [message #78216 is a reply to message #78212] Mon, 28 October 2013 19:10 Go to previous messageGo to previous message
Thanks Wayne,
I'll try the t-nuts, but as I already have the boxes done, it could be a little harder than the normal wood screws...
but I follow your recomendations Smile
Current Time: Sat Oct 24 18:00:33 CDT 2026
