Home » Audio » Source » DAT to CD
DAT to CD [message #78151] Sun, 20 October 2013 12:38 Go to next message
I found an old DAT and some zip discs with audio projects on them. I know someone with a zip drive so transferring those won't be an issue, but I don't have a DAT machine. I guess it would probably be easiest to reach out to a local production studio and see if anyone can convert it for me, huh?
Re: DAT to CD [message #78157 is a reply to message #78151] Mon, 21 October 2013 05:22 Go to previous messageGo to next message
Round2 is currently offline  Round2
Have you tried searching online to see if you can rent one in your area? There are some places when you search on Google that rent them out and it may be cheaper than having someone else do it.
Re: DAT to CD [message #78188 is a reply to message #78157] Thu, 24 October 2013 17:16 Go to previous messageGo to next message
It would take two steps but you could feed them into a PC and then make CDs from the PC files. There is lots of free software that will do the job. It does assume you have a good sound card or other interface device that will not degrade the bit and sample rate of the originals.
Re: DAT to CD [message #78196 is a reply to message #78188] Fri, 25 October 2013 07:33 Go to previous message
gofar99 wrote on Thu, 24 October 2013 18:16
My sound card isn't that great, and in any case, I don't have the hardware to play the DAT. I haven't even seen a DAT machine in years.
Previous Topic: One sided record albums
Next Topic: need help with replacement receiver
Current Time: Mon Nov 09 07:26:56 CST 2026
