Home » Audio » Thermionic Emissions » Why parafeed?
Why parafeed? [message #77793] Sat, 07 September 2013 22:02 Go to next message
The title says it all. Why? Why do so few manufacturers use them?
Steve
Re: Why parafeed? [message #77794 is a reply to message #77793] Sun, 08 September 2013 14:23 Go to previous messageGo to next message
Hi Steve, Cost is my guess. Plus a few other things that might complicate the design. The output device(s) will see two different inductors. Regardless of their respective values it will introduce anomalies. The primary benefits would be to SE amplifiers. Then the dc power would not have to go through the output transformer. This would make it possible to use a much smaller output trannie as you would not be likely to saturate it. In push-pull designs I see no value as if operated within spec. A PP output transformer should never saturate.
Re: Why parafeed? [message #77856 is a reply to message #77794] Sat, 14 September 2013 19:11 Go to previous messageGo to next message
Thanks Bruce.
Re: Why parafeed? [message #86325 is a reply to message #77793] Sat, 14 October 2017 16:57 Go to previous messageGo to next message
Zohanna is currently offline  Zohanna
Wow, you guys are so savvy here that I'm embarrassed about my relative novice. Can someone explain Para feed to me? I don't even know what it is.. Confused
Re: Why parafeed? [message #87874 is a reply to message #86325] Tue, 24 April 2018 21:04 Go to previous messageGo to next message
hudelson2 is currently offline  hudelson2
Normally the primary of the output transformer is connected to B+ voltage and the plate of the output tube. In a single ended amplifier there is direct current passing though the output transformer. There has to be a gap in the core to keep the core from being saturated. Then you need an expensive large transformer to pass low frequencies.
Parallel feed (parafeed) has the DC passing through a separate inductor from B+ voltage to plate of the output tube. There is a DC blocking capacitor to the output transformer. Since there is no DC passing through the output transformer no gap is required in the transformer core so the transformer can be smaller and cheaper.
See https://www.tubecad.com/2014/09/blog0308.htm for further explanations.
Re: Why parafeed? [message #93795 is a reply to message #87874] Thu, 20 May 2021 23:52 Go to previous message
I think the RCA Radiotron Designers Handbook, Edition 4, by 26 engineers,
page 519 sheds some light on the subject of parafeed operation.
"In all cases when making use of any resonance effects involving the inductance of the transformer primary, it is important to remember that this is a variable quantity. Not only are there considerable variations from one transformer to another, but there are large variations of inductance caused by the a.c. input voltage.
The series resonant circuit presents a low impedance to the valve at the resonant frequency, thus tending to cause serious distortion, particularly when the valve is being operated at a fairly high level. For these reasons the resonance method is not used in good design."
For ease of understanding for newbies, the inductance varies with power/spl, the load line varies, and the low frequency resonance frequency varies, the bass varies with loudness.
Cheers
pos
Previous Topic: I didn't know about NOS tubes
Next Topic: Point to Point vs PCB
Current Time: Fri Nov 06 22:03:05 CST 2026
