Home » Sponsored » Pi Speakers » 100W resistor in 3Pi crossover (How to avoid 100W rating)
100W resistor in 3Pi crossover [message #77393] Sat, 03 August 2013 01:06 Go to next message
master mind is currently offline  master mind
Hi!!!
I am in a position to buy crossover components for my 3Pi speakers. But unfortunately I am not getting 8 Ohms 100W non inductive resistor any where.
Laughing Is 100W mandatory? How can I manage this?
Re: 100W resistor in 3Pi crossover [message #77394 is a reply to message #77393] Sat, 03 August 2013 02:37 Go to previous messageGo to next message
biglaz is currently offline  biglaz
Have you tried Parts Express.
Re: 100W resistor in 3Pi crossover [message #77395 is a reply to message #77394] Sat, 03 August 2013 03:54 Go to previous messageGo to next message
I have checked with Parts Express & Parts Connection it is perhaps out of stock.
Pls. help me.
Re: 100W resistor in 3Pi crossover [message #77396 is a reply to message #77395] Sat, 03 August 2013 10:33 Go to previous messageGo to next message
See page 66 of the following document:
That shows the voltage across the Zobel resistor, which then lets you know the power dissipation required of this part. The drive voltage to get to this point is 70v peak, which is 50 volts RMS, equivalent to about 300 watts across an 8Ω load.
What you should take from this is that component needs to be able to handle at least 1/3rd the amount of power applied. So for example, if you use a 10 watt part in this position, your speaker is safe to about 30 watts continuous power. It can handle higher peaks than that, and it is only vulnerable in the upper midrange, around 1kHz. But those are the facts. It can't handle more than about 3x the power that resistor is rated at 1kHz, and should be considered vulnerable from 500Hz to 3kHz.
My suggestion would be to order the right part and install it when it gets here. In the meantime, you can install a smaller part in that position, and derate the loudspeaker accordingly. Just go easy on the power knob 'til you get the right part.
Re: 100W resistor in 3Pi crossover [message #77397 is a reply to message #77396] Sat, 03 August 2013 11:06 Go to previous message
blvdre is currently offline  blvdre
Mouser has them (Non-Inductive):
http://www.mouser.com/ProductDetail/Arcol/NHS100-8R0-1/?qs=sGAEpiMZZMvNd0dY0KymzlaqmssbCLc763m%252b2vA9eww%3d
Previous Topic: 4Pi How good are they actually?
Next Topic: Every Upgrade makes the 4Pis Better
Current Time: Sun Nov 01 06:02:13 CST 2026
