Home » Audio » Room Acoustics » New Addition
Re: New Addition [message #77035 is a reply to message #77027] Sun, 16 June 2013 16:25 Go to previous message
Hi, I used double layers on the outside (sheathing over plywood) and had the seams offset. I used 4 inch fiberglass in the walls with a poly vapor barrier. The inside surface was 1/4 inch paneling. I dropped the ceiling and used 6.5 inch fiberglass between the 2X8 joists then installed a suspended drop ceiling of absorbent backed ceiling tiles. With a thick carpet and pad on the floor. Nice isolation and the interior panels are just lively enough to keep the room from being too dead.
Previous Topic: More sound up front?
Next Topic: Bright Star IsoNodes
Current Time: Sat Nov 07 03:25:20 CST 2026
