Home » Audio » Room Acoustics » New Addition
New Addition [message #76756] Thu, 16 May 2013 14:47 Go to next message
I'm building a new addition to my home which will be adjacent to my garage. My question is how thick should I make my walls for the best soundproofing and listening effect? This will be my writing/music room.
Re: New Addition [message #76889 is a reply to message #76756] Thu, 30 May 2013 08:09 Go to previous messageGo to next message
I'm not sure how wide your wall needs to be but put some insulation in there. You could also do a double layer of drywall and you can get some whisper clips that will isolate the drywall from the studs, so vibration isn't transmitted between adjacent walls.
Re: New Addition [message #76926 is a reply to message #76756] Mon, 03 June 2013 06:14 Go to previous messageGo to next message
Chicken is currently offline  Chicken
I hadn't heard of whisper clips until now, but what an ingenious idea! Any time you can isolate vibrations to the surrounding materials, it helps with soundproofing and overall quality.
Re: New Addition [message #77027 is a reply to message #76756] Sun, 16 June 2013 06:30 Go to previous messageGo to next message
Oh yes, vibration isolation is incredibly important for soundproofing and quality. Whisper clips are a great invention. Speaker stands that isolate the speaker are good to have for clean sound as well.
Re: New Addition [message #77035 is a reply to message #77027] Sun, 16 June 2013 16:25 Go to previous message
Hi, I used double layers on the outside (sheathing over plywood) and had the seams offset. I used 4 inch fiberglass in the walls with a poly vapor barrier. The inside surface was 1/4 inch paneling. I dropped the ceiling and used 6.5 inch fiberglass between the 2X8 joists then installed a suspended drop ceiling of absorbent backed ceiling tiles. With a thick carpet and pad on the floor. Nice isolation and the interior panels are just lively enough to keep the room from being too dead.
Previous Topic: More sound up front?
Next Topic: Bright Star IsoNodes
Current Time: Sat Nov 07 02:54:30 CST 2026
