Re: Pete's Home Theater Build [message #76980 is a reply to message #76979] Fri, 07 June 2013 14:16 Go to previous messageGo to previous message
I'm definitely going with corner horns. Have not decided between the six and seven yet though. I'm working out the details on the mid-horns and plan to build them soon.
I know you've recommended using a three or four for center channel duty. What would you think about using a mid-horn, HF horn and crossover from a six or seven as the basis of a center channel speaker? I'd build a bass bin to fit the space available behind and below the screen. The seven bin would fit my space but obviously wouldn't have the benefit of living in a corner.
It might make sense to bi-amp the bass bin on one amp and the [mid+HF+passive XO] on another amp with a miniDSP active XO.
It seems that the LF driver in the corner horns covers a much smaller chunk of spectrum than the LF driver in a three or four. I'm concerned (obsessed) that the center blends seamlessly with the left and right corner horns. Since the range covered by the mid-horn is so important I'd think all three front speakers would be better matched up from mid bass to the top end with identical drivers.
Previous Topic: 4pi measurement
Next Topic: Pi Speakers FAQ
Current Time: Sun Oct 25 07:40:46 CDT 2026
