Home » Audio » Home Theater » Audio Cables
Audio Cables [message #76475] Wed, 24 April 2013 16:15 Go to next message
iLoveiPod is currently offline  iLoveiPod
I was shopping for more audio cables recently and came across gold tipped ones. The guy at the store said they're better than the cheapest audio cables they sell. Is this true or was he just trying to up his commission?
Re: Audio Cables [message #76517 is a reply to message #76475] Fri, 26 April 2013 18:59 Go to previous messageGo to next message
Kenwoody is currently offline  Kenwoody
I've had both before and I couldn't tell a difference in sound quality, however the gold ones did last longer than the cheap ones that usually come with whatever you're buying.
For the price difference, I would probably still go with the cheapest ones I could find.
Re: Audio Cables [message #76562 is a reply to message #76475] Tue, 30 April 2013 08:39 Go to previous message
Gold ones generally do last longer; I have heard it is because the gold oxidizes at a slower rate. That said, I usually don't splurge on gold-tipped cables.
Previous Topic: Theater Computer
Next Topic: Buying A Flat Screen From Sam's Club?
Current Time: Thu Nov 12 13:54:59 CST 2026
