Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #76446 is a reply to message #76444] Tue, 23 April 2013 11:03 Go to previous messageGo to previous message
Wayne Parham wrote on Tue, 23 April 2013 10:28
I don't, Жека, sorry. But I'll try and get some for you, as time permits. I was really more focused on the directivity midband up, because down in the crossover region, the midwoofer and tweeter patterns blend anyway. In the crossover overlap band, tweeter directivity is shadowed by the midwoofer.
That's also why I didn't consider a secondary flare to combat waistbanding. I wanted the flare to be purely OSEC, to make the wavefront propogation stay perpendicular to the walls as much as possible.
I am not sure I can tell from the sonograms where the waistbanding takes place. The normalized ones seem perfectly uniform all the way down to 1K.
http://www.pispeakers.com/Measurements/H290C_Horizontal_Contour_Normalized_6dB_strata.jpg
is that because of the scale?
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Sat Nov 14 13:55:04 CST 2026
