Home » Sponsored » Pi Speakers » Insulation inside of speaker: Spray Foam?
Re: Insulation inside of speaker: Spray Foam? [message #76250 is a reply to message #71596] Tue, 09 April 2013 18:30 Go to previous messageGo to previous message
Wayne,
What stuffing method do you recommend for subs (sealed and ported)? If the walls are to be lined with fiberglass, does 1" rigid fiberglass work as well as R13?
Thanks,
Darrell
Previous Topic: 2Pi Tower Plan
Next Topic: 4pi Dinner Theater Update
Current Time: Thu Nov 05 21:48:26 CST 2026
