Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #75922 is a reply to message #75909] Wed, 20 March 2013 21:26 Go to previous messageGo to previous message
The H290C is the best 90°x45° horn/waveguide available, truly a no-compromise design. So naturally, I would suggest it for any DI-matched two-way speaker or constant directivity cornerhorn.
The loudspeaker models I make using that waveguide are the ones I found to be the best out of a few dozen that once made up my line, so I find them to represent the best of the best. I wouldn't make any other design choices than those.
That said, there are plenty of other similar components that work very well. An example is the Eminence Kappa line of drivers, which are very similar to the ones I use in some of my models, and which have been used by many DIYers on this forum. There are lots of others too, lots of ways to "do it right" but of course lots of ways to do it wrong too.
So my suggestion is to study the links in the Pi Speakers FAQ, especially those in the "Crossovers" and "Simulations and Measurements" sections. Also look at the "General Information" section, especially the post called "Notes for the DIYer". It has links to some of the most useful notes for designing speakers like these. For example, "Crossover optimization for DI-matched two-way speakers" describes my exact crossover design process including a video showing how to measure the forward lobe by finding the vertical nulls that mark its edges.
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Sat Nov 14 13:55:14 CST 2026
