Wayne Parham Messages: 19103 Registered: January 2001
If the corners are unobstructed - no door openings or open windows - then that room will work very well. I generally prefer the short wall be in front of the listeners because it is easier to setup where the forward axes cross in front of the listening area that way.
Wayne is a great guy and has tons of good solid information in his FAQs.
no doors or windovs so it all good
I recall Wayne saying that you need at minimum 1m (metric for you my European friend!) of uninterrupted wall on both sides of the cornerhorns.
how much in front of the listeners should the forward axes cross?
Wayne will link to the proper FAQ piece but I think he said ~1m.
have you got an oppinion on how much power they need to sound their best?
All Wayne's speaker's are fantastic in that they are high efficiency so they run well with low power tube amps (5W) and class A amps (10W) but at the same time they are high power, 'pro'-type speakers so can take 100s of watts and sound super clean doing it!
as i am in denmark i would like to just buy the crossover from you, is that possible?
panduro Messages: 34 Registered: March 2013 Location: denmark, european union
Hello JCDC,
Thanks for the elaborate answer, its much appriciated.
will be sure to print the faqs section and use it for bedtime reading .
Yes shipping gets very expensive to denmark, plus we have to pay custums if the goods are above 100usd and vat of the amount which includes shipping grrrr, open market hmmmm my a....
yes i can source the drivers i the eu from thomann.de
eminence delta 10a 88 euro a piece
b&c de250 148euro a piece
8 euro shipping to denmark
480 euro including vat and shipping
