Home » Sponsored » Pi Speakers » cornerhorn - will my room do well
cornerhorn - will my room do well [message #75680] Fri, 01 March 2013 19:44 Go to next message
Hello Wayne,
im a long timer lurker and reader of your site and pdf's, alot of good reading Smile.
I am building a small dedicated ht/music room and has been dreaming of trying your 7 cornerhorn for a long time now.
my room is 11 x 13 feet.
im stil in the planning fase so i can orient the room as i please.
would i gett a good result with your pi sevens in that room?
speakers on short or long wall?
what would the optimal leasening distance be?
best regards
bent
Re: cornerhorn - will my room do well [message #75684 is a reply to message #75680] Fri, 01 March 2013 20:59 Go to previous messageGo to next message
If the corners are unobstructed - no door openings or open windows - then that room will work very well. I generally prefer the short wall be in front of the listeners because it is easier to setup where the forward axes cross in front of the listening area that way.
Re: cornerhorn - will my room do well [message #75685 is a reply to message #75680] Sat, 02 March 2013 04:46 Go to previous messageGo to next message
Hi Wayne,
no doors or windovs so it all good Very Happy
how much in front of the listeners should the forward axes cross?
have you got an opinion on how much power they need to sound their best?
as i am in denmark i would like to just buy the crossover from you, is that possible?
I would like plans for them emailed to bentblaabjerg@yahoo.dk if you would be so kind.
thank you for your wonderfull site and you attitude towards diy'ing YOUR speakers.
Panduro
Re: cornerhorn - will my room do well [message #75687 is a reply to message #75680] Sat, 02 March 2013 07:46 Go to previous messageGo to next message
Welcome Panduro,
Wayne is a great guy and has tons of good solid information in his FAQs.
I recall Wayne saying that you need at minimum 1m (metric for you my European friend!) of uninterrupted wall on both sides of the cornerhorns.
Wayne will link to the proper FAQ piece but I think he said ~1m.
have you got an oppinion on how much power they need to sound their best?
All Wayne's speaker's are fantastic in that they are high efficiency so they run well with low power tube amps (5W) and class A amps (10W) but at the same time they are high power, 'pro'-type speakers so can take 100s of watts and sound super clean doing it!
Shipping does get expensive! Can you get the drivers locally?
Here' the 7 Pi crossover:
http://www.pispeakers.com/catalog/product_info.php/cPath/4_47/products_id/270
and just the PCB:
http://www.pispeakers.com/catalog/product_info.php/products_id/272
The prices are just for one so you'll need two for stereo.
Wayne will email them to you!
Wayne just added the FAQ section and it is packed full of awesome info!
Re: cornerhorn - will my room do well [message #75688 is a reply to message #75687] Sat, 02 March 2013 08:19 Go to previous messageGo to next message
Hello JCDC,
Thanks for the elaborate answer, its much appriciated.
will be sure to print the faqs section and use it for bedtime reading Smile.
Yes shipping gets very expensive to denmark, plus we have to pay custums if the goods are above 100usd and vat of the amount which includes shipping grrrr, open market hmmmm my a....
yes i can source the drivers i the eu from thomann.de
eminence delta 10a 88 euro a piece
b&c de250 148euro a piece
8 euro shipping to denmark
480 euro including vat and shipping
the jbl 2226 i will find used.
thank you for taking the time Wink
best regards
panduro
Re: cornerhorn - will my room do well [message #75689 is a reply to message #75688] Sat, 02 March 2013 09:57 Go to previous messageGo to next message
Looks like JCDC answered all your questions and I've sent plans to your email address.
Thanks guys!
Re: cornerhorn - will my room do well [message #75690 is a reply to message #75680] Sat, 02 March 2013 10:12 Go to previous message
Hi Wayne,
Thank you very much.
best regards
panduro
Previous Topic: 3Pi Plans with upgraded drivers
Next Topic: Notes On Speaker Grills
Current Time: Thu Nov 12 19:04:13 CST 2026
