Home » Sponsored » Pi Speakers » Hi and a Few Questions (Hi and a few questions)
Re: Hi and a Few Questions [message #75677 is a reply to message #75660] Fri, 01 March 2013 14:40 Go to previous messageGo to previous message
Michaelzh is currently offline  Michaelzh
Thanks for answering my questions.
I remembering talking about compression ratio. The corner horn is a cube one based on your idea of conical corner horn. I have been using these corner horns for the past ten years. The cubic shape is the reason I have to build the midrange horn on my own. I will keep the inner dimensions but will have to make it such that the midrange horn aesthetically "compatible" with the square corner horn.
Wayne, do you sell DE 250 compression drivers separate from your kits? I will need to get the crossovers, the tweeter horns, and the compression drivers.
Previous Topic: How to improve?
Next Topic: 3 PI build
Current Time: Fri Nov 27 06:05:19 CST 2026
