Re: 2Pi's completed - now I want a center channel [message #75562 is a reply to message #74391] |
Tue, 19 February 2013 15:11 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
willis66
Messages: 7 Registered: November 2012 Location: Roswell, GA
Esquire |
Well the towers are complete. They are built with 3/4" MDF with bracing and insulation per plans. The veneer is cherry that I applied via the glue/iron method. It was very frustrating and they still do not look good, lots of bubbles. It was probably due to the weather and humidity. After a lot of effort they were flat, then after the first coat of laquer, sprayed with an HVLP sprayer, more bubbles appeared. I decided to listen to the for a few months and try again this spring. They do sound great and having the center channel match is great. Running the fronts with a 150HZ filter. Overall I love the sound, just got to work out the veneer issues. Next time I might just build with Baltic Birch and stain the birch.
The new flexi racks are stained in the same color has the towers, I like the overall look.
Still trying to decide if I should make the screen smaller, or just ignore, since when watching 2.35:1 movies it is goes unnoticed.
The pics..
Attachment: P1060150.jpg
(Size: 427.15KB, Downloaded 2999 times)
Re: 2Pi's completed - now I want a center channel [message #75585 is a reply to message #74391] |
Thu, 21 February 2013 07:06 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) |
willis66
Esquire |
Thanks for the reply Wayne. I am not planning on adding anything else, and honestly what we have now actually looks good in the room.
My main concern is that the existing treatments might somehow be hurting performance, especially in the left front corner. From your response it sounds like leaving everything as is will be fine.
I do not have test equipment, just a SPL meter from Radio Shack.
Going to enjoy what I have for a year or two, then consider building a 4Pi L-C-R setup and reusing the 2Pi's elsewhere in the house.
Thanks again, Wayne for all you give to the community.
