Home » Audio » Home Theater » Hiding Wires
Hiding Wires [message #75540] Sat, 16 February 2013 13:43 Go to next message
timron is currently offline  timron
We've had our home theater system up and running for a while now but we finally got around to mounting the speakers on the wall for better sound. The only problem is, now there are wires hanging down from the speakers to the receiver and I hate the way it looks. What can I do to hide those wires?
Re: Hiding Wires [message #75541 is a reply to message #75540] Sat, 16 February 2013 14:21 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
I think Home Depot and Lowe's both sell cord management products. Basically, you just gather all the cords together and then place a piece of plastic over them. You can even paint the piece to match the color of your wall so it blends in better, or leave it white so it looks like wall trim.
index.php?t=getfile&id=1032&private=0
Re: Hiding Wires [message #75544 is a reply to message #75541] Sat, 16 February 2013 17:32 Go to previous messageGo to next message
...Or run them through the walls, and install wall plates at each end for connections.
Re: Hiding Wires [message #75650 is a reply to message #75540] Wed, 27 February 2013 06:53 Go to previous messageGo to next message
Chicken is currently offline  Chicken
If you are sure everything is placed the way you want it to remain, running cables through the walls is the way to go. It's a bit of a pain but it looks better. If you like to rearrange things, though, the cable hiders are a better bet.
Re: Hiding Wires [message #75699 is a reply to message #75650] Mon, 04 March 2013 06:06 Go to previous message
Chicken wrote on Wed, 27 February 2013 07:53
We rearrange things too often to run cables through the walls, so we opt for the cable hiders. They are definitely not as attractive though.
Previous Topic: Digital Antenna
Next Topic: Pre/pros in THX small in number big in price
Current Time: Fri Sep 27 12:22:34 CDT 2024
