Home » Sponsored » Pi Speakers » Buffer for my system? (Buffer)
Re: Buffer for my system? [message #75516 is a reply to message #75493] Tue, 12 February 2013 18:39 Go to previous message
Les Winter is currently offline  Les Winter
You may not have the problem you think. The tube amp may have an input impedance near 500K which, compared with the others, is neglegable. I would suggest that you can call the sub manufactures and ask what impedances the sub amps are. If I remember correctly, my parts express plate amp was around 18k. A pair of 18k's in parallel is a manageable 9k. The tube amp's presence would then be hardly noticable if at all.
That said, I use a b-1 to avoid having a passive master volume control. Nelson Pass writes about the subjective sound this produces in his B-1 article.
My b-1 works great, adds litte or nothing I can detect and is not finicky to wire up. It is running constantly for several years w/o issues.
good luck.
Les
Previous Topic: 6π bass driver question
Next Topic: Skywave's 3 Pi Build
Current Time: Thu Nov 05 17:27:58 CST 2026
