Home » Sponsored » Pi Speakers » Alternate idea for 7Pi midhorn enclosure?
Re: Alternate idea for 7Pi midhorn enclosure? [message #75410 is a reply to message #75395] Fri, 01 February 2013 10:59 Go to previous message
altecguy wrote on Thu, 31 January 2013 01:06
Hi, I was wondering if a box enclosure could be fit at the end of the midhorn to house the delta 10 and leave the outside flare of the horn exposed? As long as the volume of this box follows the guideline, I don't see a problem except for increased depth. All exposed surfaces of the midhorn could be veneered for a nice look.
Thanks
Sorry, to derail your thread! I too am trying to make the midhorn higher WAF.
Your idea of no outer box for the midhorn is what I was thinking too. You could do it a different colour or veneer! As well, if you make the box surrounding the back of the driver a wedge shape, it could fit further into the corner ... but then you're want to push the tower15 further into the corner ... and then you're changing the design.
Cheers,
Jeff
Previous Topic: Anyone Gone From A Planar Type Speaker To 4Pi's
Next Topic: skywave's 3Pi subwoofer build
Current Time: Mon Oct 19 22:56:13 CDT 2026
