Home » Sponsored » Pi Speakers » Subwoofers vs budget... where do you draw the line?
Re: Subwoofers vs budget... where do you draw the line? [message #75265 is a reply to message #75260] Tue, 15 January 2013 21:39 Go to previous messageGo to previous message
Hi j0nny,
A lot of sub plate amps have high-level inputs as well as the normal low-level RCA inputs that connect to an AVR's pre-outs. To use the high-level inputs just connect them in parallel to the same speaker wires as the main L/R speakers. Note unlike an actual speaker, the high level amp inputs have a very high impedance so you don't have to worry about overloading your main speaker's amp.
This is not the ideal way to connect signals to your plate amps, but it beats buying a new receiver or ditching flanking subs all together.
Previous Topic: Old veneer method, new to me...and it worked!
Next Topic: 4Pi and 7Pi Plans
Current Time: Fri Nov 06 05:35:14 CST 2026
