Home » Audio » Pro Sound » Guitar Head Amp Features
Re: Guitar Head Amp Features [message #75264 is a reply to message #75259] Tue, 15 January 2013 21:39 Go to previous messageGo to previous message
Hi Shane, Good thoughts, but since I have designed it to be clean to start with and figured it was then easier to fuzz it up, the amp should play clean down into the milliwatt range. It's just one of those thing I do. With only a simple resistor network on the output to maintain a load... any of my amps up to the KT120s could be used for a headphone amp. Not real efficient use, but clean and quiet. It is possible to add a reduced power setting though. The 16 ohm output tap is a good idea and easy to implement. As a non-musician.... how would you describe the difference between lead and rhythm.
I got the rest of the parts yesterday, so a build is about to go full steam. Gray crackle, gloss red or blue or plain silver for color .... such choices.
Previous Topic: 12 String Guitars
Next Topic: Electric Guitar VS Acoustic
Current Time: Fri Oct 16 07:34:57 CDT 2026
