Guitar Head Amp Features [message #75180] |
Tue, 08 January 2013 10:23 |
gofar99
Messages: 1944 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi Everyone, I'm looking for some input from the musician community out there. I'm in the final stages of design and prototyping of a head amp and would like to get some feedback on the features wanted / needed etc. The design is all tube with push-pull output of about 25 watts clean. It can use 6L6GC (initially 6L6WXT+), EL34 and similar tubes. Use is expected to be lead or rhythm, but bass use is possible as the low end response is clean and linear to below 20HZ.
Tentative features
Input level control
Main volume control
Full tone stack, bass, mid, treb
Clean switch, bypasses the tone stack
External feature inputs, like fuzz, reverb etc
Two inputs, low gain and high gain
4 and 8 ohm output
I have initially planned to have 1/4 inch standard phone jacks for inputs and external feature connections.
Are balanced 1/4 inch or XLR connections needed?
Your thoughts are appreciated. In the clean mode, I expect this will be among the sweetest ever done. As for the other modes...it is always easy to add the features.
Re: Guitar Head Amp Features [message #75971 is a reply to message #75970] |
Fri, 22 March 2013 20:31 |
gofar99
Hi Chris, That is true ...if the amp did nothing but clean then there would be little demand. However it is designed to overdrive in two different modes, both in the input stage and in the output stage. Or for that matter both at the same time. My thought process is to design something clean and then add the flavor to it. That way it can be adjusted to get what sounds right. Thanks for the insight.
