Home » Sponsored » Pi Speakers » Subwoofers vs budget... where do you draw the line?
Re: Subwoofers vs budget... where do you draw the line? [message #75248 is a reply to message #75247] Mon, 14 January 2013 21:31 Go to previous messageGo to previous message
j0nnyfive is currently offline  j0nnyfive
Ahh...
Just so I understand, to compare this to your "typical" home theater arrangement where only one sub would be used and the receiver would be set to crossover at 80hz... instead, I would use 2 flanking subs and set the crossover (in the receiver) to 100hz or maybe a bit higher? Because I don't have to worry about localization since the subs are close to the speakers? But these 2 subs (since they are my only subs) would ALSO handle all of the bass, period? I just want to make sure I'm not missing anything. Nothing "special" needs to be done to these subs? Like, no special connections between the flanking mains or anything?
Previous Topic: Old veneer method, new to me...and it worked!
Next Topic: 4Pi and 7Pi Plans
Current Time: Tue Oct 20 22:22:28 CDT 2026
