Home » Sponsored » Pi Speakers » Looking for some Pi advice for theater ... (4pi vs 7pi)
Re: Looking for some Pi advice for theater ... [message #75240 is a reply to message #75238] Mon, 14 January 2013 14:52 Go to previous message
I was thinking the wall behind the screen was solid, and that the cornerhorns would be placed there. Are you saying you were planning to bring them forward to where the screen is?
If so, if what you are saying is they would sit near the trim which spans from sidewall to screen, what is the trim made out of and how large is it? How many feet from the apex of the corner?
The screen is probably acoustically transparent, so it won't act like a boundary. So I am thinking your "stubs" of trim won't be enough to support the cornerhorns.
You could do one of two things:
1. Push the cornerhorns back into the corner and use an acoustically transparent material to span the gap between screen and sidewall.
2. If the trim is made from a panel that is wide enough to hold a loudspeaker, create a soffit to hold four Pi speakers. But in this case, I think the soffit might be small enough you may want flanking subs. Have to measure it and see.
Previous Topic: Pi 1 plans please
Next Topic: Old veneer method, new to me...and it worked!
Current Time: Fri Nov 06 05:13:14 CST 2026
